I have multiple references attached to files, one of which is the Title Block file. Within that Title Block reference there is a shape on level PLTBDR which is within a cell. I setup a default print style that defines the fence by Shape which I set to find level PLTBDR. It works on 1 of the files but 4 it doesn't. I have looked into the files and cannot come up with anything. I've can send the files if needed. Technical difficulties loading the files to this post :)
MIke
I would guess that the files not working contain reference clip masks. Print Organizer has a known problem finding shapes inside references that are clipped via masks. You can either remove the masks from the title block reference, or you can contact Bentley Support. They may be able to provide a build that fixes the problem.
