Hi, I can’t use Print Organizer. Print Organizer doesn’t show up uploaded designs. Instead in the massage centre appears: Exception encountered inside [WorkerMicroStationProxy.LoadDesignFile] (The server did not provide a meaningful reply; this might be caused by a contract mismatch, a premature session shutdown or an internal server error). Has anyone had the same problem? How did you resolve it?
What version (i.e. v##.##.##.##) of MicroStation are you using?
MS V8i - version 08.11.05.17.
Perhaps some of the information and workarounds included within the following thread may help to resolve this issue for you. communities.bentley.com/.../12377.aspx If not, please open a Service Ticket with Technical Support so that they can work directly with you to help resolve this issue. You can start a service ticket at the following location: appsnet.bentley.com/.../addcall.aspx
