In the print dialog box under "Printer and Paper Size" there's a drop down box where I can toggle between "Send to Printer", "Create plot file" or "Create metafile". Is there any way to set the default to "Create plot file". My default is "Send to Printer" and I ocassionaly get in a hurry and don't change that and bang - it's sent to the plotter. Would like to change if at all possible.
Thanks.
In the Printer Driver Configuration Editor for printer.pltcfg, under the Default Print File Name category, specify a plot file name and extension. You can use the values in pdf.pltcfg as a guide.
Note that if 'Auto Overwrite File' is set to True, the Print dialog will automatically create the plot file without prompting you with a File SaveAs dialog.
