In the define print styles dialog for the print ogranizer, it doesn't appear you can select a plot driver from ProjectWise? Clicking the browse button only goes to your typical windows dialog. Oddly enough, when selecting a pen table, you can navigate to PW. Also, I've tried to just put the name of the driver without a path, hoping it would look in my MS_PLTCFG_PATH or MS_PRINTDEF_PATH search paths, but it does not. I get an error the first time the dialog is opened saying it can't find the file in the search paths, and the paths that are displayed in the message box are not the ones defined in our managed workspace in PW--they are to my local "Documents and Settings" folder.
Thoughts?
Also, there appears to be an issue with an ampersand "&" being a part of the pen table name. For example, our pen table is named "b&w_ANSIB.tbl". The print style dialog reloads this to "b&w_ANSIB.tbl" causing our pen table to not be found. Thoughts (other then removing the "&")?
