Picking a printstyle, other than the default, via the "Apply PrintStyle" selection of the print dialog box is very slow. I have tried to simplify things as much as possible by having only (2) .pltcfg files where line weights and linestyle scales are set for laser printers and Xerox 510 printers, then having multiple printstyles that access the different printers, paper sizes and color or monochrome. I believe that when the printstyle is selected there is processing of the print happening prior to sending the print to the printer, but it does seem excessively slow. Is the normal, or is there something I can do to speed things up. Using Print Organizer eliminates this slowness, but for individual plots as people are used to it is slow.
