In PO, tools, define print styles, on the Display tab the boxes have 3 choices:
solid, empty and check
what is the different between the 3?
thanks!
If checked, that means the attribute option is turned on.
If there is a solid filled in block the attribute is, As set in file.
If blank solid the option is turned off.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
thanks...what file?
The file that you are printing. Think of it as an Attributes override. You could have Construction lines displayed in your drawing as you are viewing it on the screen. Instead of turning them off on screen and then printing, you can just have Construction lines set to not plot in the print attributes. That way you do not accidentally plot the construction lines.
The checkboxes apply to the print (dgn file, or model) being processed. These are the same as the Print Attributes in the regular Print dialog, which allow you to override the file's view attributes.
Since PO processes multiple dgn's and/or models it gives you the options to:
Rod WingSenior Systems Analyst
That makes it clear...thanks!
Thanks for the detail RodWing. That's what I was trying to say.
