Saving Print Attribute Settings
 I would like to save the LINE WEIGHTS toggle ON under the Print Attributes settings. Does anyone know how to do this.
I am aware of Print Styles and we have some setup, but I still would like to set my Print Attributes.
  • Usually if you have Line Weight display in the view attributes of the dgn file, the line weights will be checked on when you open the print dialog. If you open the print dialog with line weight attributes off you will need to manually set line weights on in plot attributes. I'm not sure if you can set that attribute on in the plot driver.
    Mike
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • Thanks Mike and I agree with what you are saying. But it really seems silly that I have to go through that step every time I start the print command. Don't you agree?
