V8i .pltcfg loading EXTREMELY SLOW
I have a problem with MicroStation V8i being extremely slow when we change “PrintStyles”. I have narrowed it down to not being the actual “PrintStyle” in the dgnlib file , but the .pltcfg file that the “PrintStyle” calls. As I said, I have disabled MicroStation from looking at the dgnlib with the “PrintStyles” and simply manually selecedt the .pltcfg file.
·         Slow with all .pltcfg files, except the PDF  .pltcfg’s that don’t actually call a network printer.
·         When I say slow, it takes 3-5 minutes before the print dialog is ready to print.
·         This is only with  V8i SS2 version # 08.11.07.443
When testing in V8 XM version # 08.09.04.88 it takes only seconds before the dialog is ready to print.
I have attached a sample .pltcfg file. (at least I think I did)
I don't know if it is how we have the printers set-up on the Network or not, but it is strange the difference between XM and V8i.
Note:
System Info: Windows 7 Professional, Intel Xeon 2.27 Ghz, 4 GB RAM, 32 bit OS, NVIDIA Quadro 2000 - Driver: 8.17.12.7071
MY_510_C-Size.pltcfg
  • The way your .pltcfg file is set up the driver loads your Windows default printer. At least it does on my machine. How is your plot style set up? I set up a plot style to load your .pltcfg and everything loads fine here. Maybe something in your plot style is the problem. Post your plot style settings.
    Microstation CONNECT 10.17.00.209
    ORD CONNECT 2021 R1 10.10.1.3
    Microstation v8i SS 10 08.11.09.919
    Power InRoads v8i 08.11.09.615
    ProjectWise 10.0.3.453
  • Unknown said:
    I am defining the windows printer as well as the paper size in the printstyle to minimize the number of pltcfg files. I will however try to have it defined in the pltcfg and see if that helps.  I don't understand the difference in XM and V8i when the plot config is attached manually though.
    Problem solved.
    By defining the windows printer in the .pltcfg it now runs quickly as it should.  I guess it was searching for a printer and when it finally did not find it looked at the printstyle where it was defined.
    Thank everyone for their input.
    [V8i SS4  08.11.09.829, BRCM, Promis-e, OpenPlant Modeler, OpenPlant PID, STAAD, RAM, ProSteel, InRoads, FlowMaster, Map, PondPack, StormCAD, Descartes]
  • That's great. I do see a problem with this. If you use that plot style in Print Organizer you will likely have an issue. In PO, when using a plot style that has a .pltcfg defined within it, this plot style will cause havoc. There are other threads on the subject if you care to search for them.
