Transparency PDF Printing Element Fill v Gradient Fill
Hi All,
I have some elements with element fill and others with gradient fill and wish to print both with transparency. I am finding that the element fill will print transparent but the gradient fill does not unless I use Rasterized ON mode which gives me a slightly different outcome for the rest of the image.
Is this normal behaviour or is there another setting I need to look at?
John Davidson
  • Hello John,
    Is the slight difference in the colors when you compare the data in the dgn to the result in the pdf, or is the are you comparing the print preview with the pdf result?
    Can you please provide and example dgn including your pdf.pltcfg and screenshots for better understanding?
    Thank you.
    Best regards,
    Henk
  • Hi Henk,
    I did a bit of experimenting with driver settings and found that I have the rasterizing of vector elements (Raster Quality Factor) was set to a low value, when I set it to 70% or more the result was satasfactory.
    I was never sure what the settings did because there is two Raster Quality Factor settings, one in the Raster Printing section and the other in Advanced and it is not clear what each does.
    Thanks for your help.
    John.
Reply
  • Hi Henk,
    John.
