I have created a default print style which should enable "level override" when printing. If Fence is placed and then opening Print dialog it shows "default print style applied" but print attributes are not set, only paper parameters. If loaded manually by Setting->Apply print style then it loads correctly.
Is this partial loading of default print style by design?
Tried on both v8i SS2 & SS3
Nope, didn't work either. Still if trying to print Fence contents then "level overrides" are disabled. Seems need a macro or something to lock the "print attributes".
I made a test driver that has a Print Style defined in the plot driver and when I loaded the driver the print style was applied and the Print Attributes changed to what was defined in the Print Style. I don't know of any solution for you.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Did you try to print Fence?
Yes, I usually always print by fence.
