I have created a default print style which should enable "level override" when printing. If Fence is placed and then opening Print dialog it shows "default print style applied" but print attributes are not set, only paper parameters. If loaded manually by Setting->Apply print style then it loads correctly.
Is this partial loading of default print style by design?
Tried on both v8i SS2 & SS3
Did you try to print Fence?
Yes, I usually always print by fence.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Strange. And level ovverides changed too?
Yes. I opened the print dialog and went to <Settings <Print Attributes and checked all options on. I then loaded my driver (after placing a fence) with a Print Style defined in the driver and all of the Print Attributes changed as set in the Print Style. We normally do not use Overrides so I checked that option on and when I loaded the driver it was unchecked.
So it is not workaround for setting level ovverides.
