When working with model spaces within a DGN file, our presentation files have several model spaces that make up various stages of our presentations. Is there anyway to have a tag of some sort printed somewhere within the printed copy that places which model space we print from?
Example: We had a new employee that couldn't figure out which model space the a printed copy came from.
Currently on our prints, we have date, user id and file name with full path to locate the file. However it would be nice if we also had the model space we were in when the print was created.
Any suggestions?
a picture says more than thousand words:
right click in the text editor / choose Insert Field / choose a Field Type / choose a Property to show / change the format settings if avail. / place your Field as simple as a text
Frank
Thanks Frank. I believe this will work.
