I have a file that doesn't print the same in SS3 as it did in SS2. The attached pdf shows dimensions that print behind some shading, making their terminators and other parts disappear which can be misleading. The pen table I am using in SS3 is the same pen table I used in SS2. The pen table assigns all dimensions and text a priority of 500 so that they print on top of everything else. I have not been able to figure out how to make the dimensions print on top of the shading. Any ideas?
Do you have any elements or levels in the .dgn file placed with priorities? If so, the combination of the Pen Table priority settings and the priorities of the elements in the .dgn file could be cancelling each other out. If you are setting priorities in both remove one or the other and see if that works. You would also need to check if any references are set with priorities.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
Bentley Support came up with a solution. For whatever reason, checking "Non-rasterized priority sort mode" under "Pen Table Options..." fixed this problem.
