I have several sheets in the same PSET of varying type. I would like to be able to apply one print definition to several large color sheets and another to print definition to several small black and white exhibits. The process I'm attempting to achieve this through is:
1)I highlight the sheets I would like to apply the print definition to.
2) Tools>Apply Print Style...
3) select desired print style
4) click OK
The print style is applied successfully to the highlighted sheets. The problem is that the print style is also applied to all the other sheets in the PSET. How can I have it just applied to only the sheets I want it applied to?
This problem arises in both SS2 and SS3.
Thank you, Andrew, consider me enlightened. I enjoy using PO and hope to have it more widely used in our firm. It has been very useful (and efficient) in producing document sets and a good way to verify scale, final plotted sheet sizes, etc. It has also been easy to alter individual file settings within psets (like rasterized, raster quality, true color) when needed.
