Im unable to do a monochrome rasterized print with cut display style and filled visible edges.Setting the general setting to monochrome seems to have no affect.
This has started to appear when installing SS3...apparently the defaul drawingseed.dgnlib is using filled visible edges for cuts.
Ive customized the drawignseed to use Visible edges for cuts instead but im a bit curious why the drawingseed is using filled visible edges if rasterized printing in monochrome doesnt work(for me).
Im guessing that I have some kind of setting that is incorrect.
Ive also tried making a pen table that mapps everything to white color....then everything dissapears(probably everything is in white). Mapping to almost black works but then I cant print to color.
The print is done from a 2d-sheetmodel
The quiestion is should I be able to print(rasterized) with filled visible edges in monochrome without attaching a pentable?
Rasterized printing should be WYSIWYG. Pen table resymbolization is strongly discouraged when printing non-wireframe display styles, and most likely will not produce the desired results.
If non-pentable rasterized printing is not WYSIWYG, then that would be a issue to raise with Bentley support.
