We have 4 psets, looking to see if there is a way to combine the 4 psets into a single pset. Is there a good way to do this?
Hi Ryan,
Unfortunately there is not a utility to combine multiple Print Set files into one. The following Change Request is filed.
CR 339023
User requests the ability to link psets into one large pset in Print Organizer.
-Todd
Has there been an update to MicroStation to combine multiple Print Sets since Ryan's request?
This would be very helpful.
BTW
PRE CE
Batch plot job files could be combined no problems as long as all the parameters were the same ie printer, pentable , paper size , print definition etc.. ..with copy paste the drg file names from one in to the other
Lorys
what about a macro or script file to load and run the PO and its Psets one after the other... if you have to do it a lot through out the project its worth the trouble to write it and it could be modified from project to project?
