I am having a problem with the line weights for all my patterns.
No matter what line attributes I place a pattern with, they only print as a really thick line. This has only happened since I upgraded to version 08.11.09.357 - Previous versions didn't have this problem.
I haven't changed my pen weight file in any way. Even older files print incorrectly now. I cannot seam to find any way to override the pen weights of patterns. Has something changed in this version that I don't know about?
I have attached an example:
The PDF shows what my print looks like. The borders are 0.25mm thick, and the pattern on the left should be 0.01mm thick, but clearly it looks thicker than the border. The pattern on the right should be 0.18mm thick, but again the pattern looks thicker than the 0.25mm border.
Can only attach one file at a time it seems, here is the PDF
And here is my pen table.
Anyone?
Tested your data and could not reproduce the problem. Will investigate further.
what happens when there is no pentable attached and only use overrides to change the level line weight attributes ( check overrides is actually on via control B)
Lorys
