I am having some trouble plotting some sheets with the Print Organizer. There is one linestyle that won't plot right. It comes out as a straight line. It doesn't make sense to me because it is stored in the same .rsc file as all the other linestyles that are plotting correctly.
The line plots fine if I print the files individually, but obviously I don't want to have to plot each sheet each time I need to create a PDF. I also noticed when a coworker opened the file on their computer, the same linestyle doesn't show up, but all the others do.
I would appreciate any input.
Jorge
Print Organizer’s background process may need to open the design file in read\write mode. Certain print workflows may depend on the design file being writeable. In Print Organizer select Edit > Preferences, disable “Open design files in read-only mode”.
You can also set MS_PRINTORGANIZER_OPEN_DGN_READWRITE = 1
Answer Verified By: jrueda
You, sir, are a genius. It worked, thank you.
