Hello all,
I'm trying to create a text substitution that will insert a range of characters from the file name.
For example, I have a dgn named 123_plan.dgn.
My border contains the text $DGNNUMBER$
I have defined a text substitution in my pen table as follows:
Actual Replacement
$DGNNUMBER$ _FILES_
The result, of course, is that if I print 123_plan.dgn with this pen table, I get "123_plan.dgn" in my border in place of "$DGNNUMBER$".
What I'd like to do, is modify the replacement to only part of the filename. What would I need to do in order for the replacement to show "123" instead of "123_plan.dgn"?
Thank you.
You could write a VBA macro to read the active filename and after extracting the number, store it in a CFG variable. Then a pen table can substitute the variable for some string in a file. The code would have to be in an event handler that runs when a file is opened. There are examples on the Ask Inga Wiki area.
The following named expression will work using your example. It picks up the file name starting at character number 4 and grabs the next 6 characters.
System.String.SubString(System.Path.GetFileNameWithoutExtension (PrintDefinition.SourceFile), 4, 6)
Answer Verified By: Roger Tango
Dawn, your answer looks like what I was after, but I seem to be suffering from a bug that prevents me from using the system symbol sets in my named expressions (as described here: communities.bentley.com/.../241553.aspx) So I can't test it! This is frustrating.
What version of MicroStation are you using? I tested with 8.11.9.459 and I have everything I need.
I have Version 08.11.09.397, which, from what I gather, was installed as a prerequisite to Inroads SS3. This is my complete symbol set list:
