Hello!
So the issue that I am having is whenever I try to print out a sheet, it doesn't come out centered.
The version that I am using is V8i select series 2.
I'm in sheet space when I print so I don't make a fence around what I am printing.
I go to iPlot, select my sheet size, a 36x48 sheet size which is the only sheet size that would fit my drawing. My drawing is only 34x44, so I want it to be centered when I print.
Then I change my X and Y size to 34x44, then I go to Tools and click Center. The image looks like it centered in the Y direction but not the X so I go to X origin and change it to 2 inches.
So now the image looks like its completely centered on the sheet but when I print it out, the very top of the image is at the top of the sheet. Its centered in the X direction but the top of the image is no longer on the sheet. What am I doing wrong?
Thanks in advance!
Have you tried printing the file after centering it and not adding 2 inches to the X origin?
