So this issue just recently started occurring and I have tried many different thing to try and remedy it. If I print from the normal print dialog I get a perfect print, but when I setup the exact same print for 20+ documents then I end up with no rasters in my .pdf's. It is very frustrating because the alternative is extremely time consuming to do printing them one at a time to individual files and then combining them.
I am printing with print organizer having it find shapes by layer for the fence for each sheet each sheet and in the advanced pane I have print raster images checked. I also validated that the print option is selected of each image in the raster manager.
Any idea?
Thanks, Matt
I can post my .pset file or some pictures if that would help
Does the raster show up if you preview the plot from Print Organizer? What is you create a PDF from one print definition in Print Organizer instead of printing them all? Are you using the same workspace/project name in Print Organizer that you are using in the MicroStation display when the Print dialog works?
1. No The Preview shows a blank screen with my border
2. No even for just one print definition I get no rasters
3. Everything is the exact same including pen table/workspace/project
Try moving the raster to the background and see if this makes a difference. Another test would be to select Rasterized in Print Organizer, does this make any difference?
I just tried both of these solutions and neither of them worked. Any other ideas?
Would it be possible to get a sample of your data?
