Why is taking 10 to 15 minutes to print a PDF?
I think we need more information. What type of file are you printing (vector data, raster images attached)? What is the sheet size of the output (ex. roll plot 36x120)? Are you using transparencies? Are you using the Bentley supplied pdf.plcfg & what settings are defined for resolution?
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
We are mainly printing vector data, but do have files with attached raster images. The output is single sheet 11"x17". We do use transparencies, the Bently supplied pdf.plcfg and the resolution is 1200 for both vector and raster.
Unknown said:pdf.plcfg and the resolution is 1200 for both vector and raster.
change it immediately to 300dpi you will see time consumption is decreasing well
Frank
Unknown said:change it immediately to 300dpi you will see time consumption is decreasing well
I second that opinion. You will see a big drop in time.
