I have a set of Plan over Profile sheets that have Mr. Sid files attached. When I use the plot driver in MicroStation, the preview shows the raster files. When I use the driver in Print Organizer, neither the preview nor the output shows the raster files.
This same pset file worked a few days ago. This is maddening!
Hi Caddcop,
Not sure what is going on with print organizer and raster, but it seems you are not the only one having problems.
Here is another related thread (communities.bentley.com/.../90330.aspx).
If you can send me some dataset I'll be glad to investigate further the problem.
Mathieu
Any movement on this? I'm having the same problem with PDF's.
Ben,
We have seen this symptom when Descartes and Inroads are installed together and when Bentley Map and Descartes or GEOPAK are installed together. The workaround for the Descartes \ Inroads configuration is to remove dcartes.cfg from the appl folder. The workaround for the Bentley Map \ Descartes or GEOPAK configuration is to remove msgeo.cfg from appl. The conflict or problem appears to be with the application’s (Descartes, Inroads, Map, GEOPAK) subsystem not working correctly in non-graphics mode. When Print Organizer prints, it starts a separate 'ustation.exe' in the background (non-graphics) to print the plot. There appears to be a problem with these applications not functioning correctly in this context. I suggest posting to the application’s forum or using the application’s support channels to find a solution, if the workarounds are introducing a problem with the way you use the application.
Hi.
Do you have any new info on this problem? I have installed the latest InRoads version (.674), and the workaround is still required.
What I don't quite understand is what happens if I don't move the cfg-files back after plotting.
Is there any support tickets that I can follow on this case.
Thomas Hauglien
Reinertsen AS
Regards,Thomas HauglienSubsea CAD Engineerhttp://www.reinertsen.com/
There is a GEOPAK trouble report filed but I’m not sure about InRoads. I suggest posting to the InRoads forum or using the InRoads support channels.
