One of my colleagues has a very perculiar printing problem.
If you take a look at the attached pdf, when he opens this specific .dgn file and clicks print, the text shows with this strange character instead of the correct one (3). If he then leaves his print dialogue box open and prints again, it prints correctly as per page 2 of the PDF. Does anyone have any idea as to why this is happening??
When I remove the sensitive information the problem rectifies itself though. Catch 22!
I would suggest opening a service ticket with Bentley support. You can send your data to them so the general public is not seeing your sensitive data and they can direct you accordingly.
Microstation CONNECT 10.17.00.209
ORD CONNECT 2021 R1 10.10.1.3
Microstation v8i SS 10 08.11.09.919
Power InRoads v8i 08.11.09.615
ProjectWise 10.0.3.453
If file is confidential, it can be uploaded using Be Communities Secure File Upload - this file will be available only for Bentley colleague. If you are going to create Service Request for Technical Support, we still will need this file.
Uploaded it for Bentley to take a look.
delete all of the faulty text that has the / in it ...
copy some ok text and edit it to replace the bad text and it should go away...
Lorys
