View attributes not saved when set
Good day all
I have a peculiar problem with my computer.
I have a set of sheet models. I have changed the view attributes of each model, specifically turning the "Fill" field on for each view.
Two things happen
1. When I use the print organiser to print all my sheet models, the "Fill" does not exist anymore, and where i had hatching and fills, will just be a blank. It is as if it does not save the changes i make to the view. i dont know why?
However if i print that sheet directly, by pressing "Ctrl P", the fills will show.
2. When I change the View settings, after closing the file and reopening it, the "Fill" setting has reverted to the original setting, and I have to go through each model if i want to re- print the sheets after changes to the drawing.
Is there a global setting that i am missing? Pleases help.
I am currently using a MicroStation V8i (SELECTSeries 3) Version 8.11.09.292, on Windows 7 - 64-bit machine.
Thank you
Parents Reply Children
