Unable to load plot driver [PDF]
This occurs when I use the plot drive to print the PDF file on Microstation V8 (8.0) at Windows 7 environment.
What can I do to solve this?
Thanks in advance.
it's probably caused by the fact you use MicroStation 8.0 in not supported environment. What you can try is to set Windows in such way MicroStation will be started in older Windows (e.g. Windows XP) mode; also you can try to start MicroStation "as administrator".
Jan
Please let us know, what MicroStation version you are using?
