I have a printer_new.pltcfg file for printer Adobe pdf. If I change a pltcfg file pdf of Microstation then, the size of the sheet also change. The Adobe pdf and pdf_new.pdfcfg have the same size of sheet with name "A3".
Why this happens?
See video.
I want create a pset file with a pltcfg file and after printing in my printer (paper) or pdf with Adobe pdf or pdf with pdf.pltcfg of Microstation, but I do not want to change the size of the sheet at a time.
Is this possible?
Thank you.
Regards.
Joaquín
I suggest setting A3 as the default paper size in the pltcfg. Refer to Andrew’s reply to the following post:
communities.bentley.com/.../39569.aspx
Answer Verified By: Joaquin
Hello Todd,
Now I understand.
Perhaps, in this case the best solution is the following:
Step 1- Select printer (pdf.pltcfg)
Step 2- Attach sheets and configuration
Step 3- Print in pdf
Step 4- Review of drawings. If is correct then step 5.
Step 5- Print in printer (paper)
Then i have the pdf and paper. The size sheet not change in pset file.
I think that is best solution for this case.
Thank you for your help.
