Dear all,
When using the detail call-out or section call-out to make a dynamic view, for use in the layout sheet, i encounter some issues.
When placing the detail in the layout sheet, the drawing looks fine until I print it to pdf or hardcopy.
the clip-volume lines are visible... (See attachments below)
some of the hidden lines come out as continuous lines as well
Can this be changed with settings i do not know of?
Hard Copy
Pdf & Hardcopy
Kind regards,
Do you have the "Rasterized" button checked in the Print Menu? If not, try that and submit another print.
Hi Marion,
This seems to be a workaround, thank you.
I hope it will be fixed for vectorized pdf's in the near future.
Answer Verified By: SvB
