Hi Friends
i have two problems last time
1. if i have open for example two views - 1 and 2 and want to open view 3 - view goes under 1 and 2 - not on top as always
( i don't know if i change something or not ? or it windows 8.1 problem ?
2. Second problem from today - i change my graphic card to GTX750Ti OC V1 ( DX11 i think ) and my illustration mode is without line edges ( like smooth )
Martin
I've had the same problem for a while (views opening underneath currently open views) - not sure if it coincides with my graphic card change to GTX 660 a couple of months ago. I'm also on windows 8.1 & Microstation 08.11.09.459
Max
Hmm, i think that is not with card because it's before changes in my case..
Any solution or reinstall ?
I'm hoping it won't be necessary to reinstall - feels like some config variable has flipped from 1 to 0 somewhere.
Not sure if this helps with the diagnosis; I'm running three HP screens off my GTX 660 (using DisplayPorts and DVI), have done very little Windows 8.1 display customization (Change the size of all items - Smaller), and I use Default 3D Settings for Microstation in the NVIDIA Control Panel.
Any suggestions from Bentley?
When you say views are you talking about dialogs?
Jerry
Hi Jerry - In my case, if I maximize View 1 on the left screen, View 8 on the right screen - and then try to open View 2.... View 2 would open but not appear on top of View 1 (ie. I would need to close View 1 to expose the now open View 2). Not sure about this but didn't opening a view from the View Toggles always force the latest view to appear on top of others that are already open?
