I have modelled a stair where 4 steps (out of a total of 15) are rotated and are NOT ALIGNED with either the x or y axis.
For those 4 steps (seen in the foreground), I have "attached a projection" for the material (the wood) and rotated it so that it is parallel with the front edge of the step. The above picture is as seen on the screen with Display Style Illustration > Ignore Lighting.
When I render this, the attached material disappears (the picture below is when it has been rendered).
Is this a bug in MicroStation (I am using 08.11.09.459), or am I doing something wrong?
TIA,Jan
Jan,
Looks like a bug, can you please email me your file.
Paul
