I'm trying to do an animation with a Descartes STM element but the animation seems to loose all its detail when creating the animation. Below is a screen capture of how the STM looks normally rendered using thematic height and underneath is how it is appearing when saving the animation.
Hi Jovan,
Ok it seems that the problem is that the height of the camera path creates some mathematical problem with the resolution selection algorithm.
The solution is to move up a bit the camera path.
Mathieu
Answer Verified By: Jovan_Djukanovic
Thanks for the solution Mathieu. Considering that I am trying to portray bathymetric data, my logic was to have the camera at sea level but I suppose this idea wont work.
