Using SS2. Do I have to convert it first? I have a bunch of .jpg and a .mtl file in the same directory as the .obj file. I see that others have done it, but I don't see anything under the import feature.
Eventual goal is to place pipe into this as a 3D model using Open Plant. Trying to eliminate having to model existing plant areas where we have not as builts.
We 3D Model everything in MicroStation and OpenPlant and would like to get this technology to work.
Answer Verified By: cswnow
