Hi There
I assigned *.ecw image tiles to my terrain model using Dcdrape and when I changed my display to smooth, my image was visible over the terrain. I had to change my image tiles, and this resulted in my terrain only displaying the color of the assigned terrain in the level manager. I removed the assignment and re-assigned the dcdrape to current terrain, this did not resolve the issue. I have removed all image tiles and unloaded my material palette, close the drawing and started from scratch but no luck.
* Working on PowerCivil SS3 (Microstation combined with Inroads)
Anybody able to assist?
Hi Megan,
Well one of the first think I would check is if the Drape column is checked.
Also I would check that DCDrape is correctly assigned to the element I want to drape with raster
HTH,
Mathieu
Answer Verified By: Megan Loock
