Hi Members!
Can you help me please about my problem with Blotchy lighting?
Thank You!
My problem:
GesFS.zip
Hi Joseph,
Have you thought of trying the Maxwell Render plugin for MicroStation? It's certainly slower than the default Luxology render engine but it gives far more predictable results.
I didn't do a good job of matching your original perspective angle but check out this comparison between the two render engines:
Cheers,Andrew.
Glow light set to 20 instead of 1000 AA filter set to Gaussian and 64 samples per pixel....
