See image below.
Settings:
Units: Meters
Mapping: Parametric
I get the feeling that the rendering part was hastily added.
Also troubles with projection mode surface
A simple cube with cubic mappingdoes not work ...
I ran some tests on existing work and to file new, CONNECT is unusable for rendering,..
continuous crash, material editor that freezes, I had to put the refresh manually to try to work
display style that cease to showing the material ...
this is not a commercial release !!!
Ciao
