See image below.
Settings:
Units: Meters
Mapping: Parametric
I get the feeling that the rendering part was hastily added.
Also troubles with projection mode surface
Hi louis,I'm trying the cdiffuse roughness, we'll see :-)
I put a little video, which shows that with units: Surface and Mapping: cubic(in this case) works
whereas with Units: meters and Mapping: cubicnot work
you can try?
Louis,
see this for the reference of material characteristics - Modo material
/pt
