I have modeled a system (lets call it the VLS) that will contain an actual (physical) camera. I want to attach a camera to the object and be able to view what I will be recording.
Is there any way I can attach the camera to the VLS model and have the VLS follow a path while the camera records the video?
David Kuratomi
Hi David,
not sure what you are asking for ...
There is an example of where a video is overlaid onto a MS session and then included in various editing scenarios .,..
a small sample is attached here which shows the video / survey lines / point cloud etc all within the Microstation session ...
Is this what you are asking for ...
or are you asking for something else ?
