The stencil tool in MicroStation Connect edition seems to ignore the line style.
Line style that has to be draped.
After draping with stencil tool.
In SelectSeries 3 this works fine.
Regards Louis
the workaround seems to be to zoom in super tight. for some reason the view affects the mesh sizes. zoom out to full extents and the dashed lines stencil as solid. zoom in tight on one or two dashes and the whole drawing gets stenciled at a much higher density, respecting the linestyles... that being said i am using the bentley delivered custom linestyles which are shapes and not simply lines with a line weight applied.
I stenciled some pavement stripes today and the linestyles were still being ignored.
When is this going to get fixed?
MicroStation Connect Edition Update 10 - Version 10.10.00.23
