I'm trying to get a decent resolution aerial image exported to LumenRT
I'm trying to attach a material using elevation drape. I've attached the material, and can even see it if I dynamically adjust it, but once I'm done adjusting, I just get a gray square. For what it's worth -The aerial does not show up in the preview window of the material editor. Are there any material settings that would obscure an elevation draped material?
Tom F
Oh - I did try Descartes, image looked good but was completely scrambled on export to lumenRT (see earlier post), as well as dcdrape.pal which cut really down the resolution, but did export to LumenRT.
David,
Thanks for the tip - I'll check the specular settings. I was able to get a decent (not as good as the Deescartes drape) looking image drape into LumenRT using Max's elevation drape method. Glad to hear your lookinig into the resolution issue.
