Hello
I have a mesh with a material applied in all surface. The material is airport of the roadway_signs.pal palette.
If i divide the mesh then i have more polygons in the mesh, but now the mesh not is a continuos surface. Each polygon is the new surface.
The material is repeated in each polygon of the mesh. The material not is one for all the mesh.
See image
If I convert the sphere in a mesh is the same problem.
Then, how can I have more polygons in the mesh and only one image of the material, in this case, of the airplane in the mesh?
Thank you
Joaquín
Aecosim 08.11.09.750_es
Answer Verified By: Joaquin
Hi Louis,
The material has Surface and Parametric. See example
Perhaps for this case, it is better Surface and Cubic, but the position of the image is rotated. This is another problema.
Thank you for your help.
/pt
