Troubles with the utility “Save Image” in MicroStation CONNECT, version 10.00.00.30
I am having some troubles with the utility “Save Image” of MicroStation CONNECT edition.  Last September a similar issue was reported about MicroStation V8i 8.11.9.536 (In the answer, Harshad was referring to this issue as Defect #314212). I already had seen this issue but only trying to save some very high resolution images.
Nevertheless, in CONNECT edition, this trouble happens for low resolution images, when the source view is set in some option with shadows.
If I want to save an image with about 1800 pixels or upper, the result will be as you can see in attached image. However this does not happen if the view does not include shadows or the image resolution is lower. The image format (JPG, TIFF ...) has not any influence on the issue.
How can I solve it?
It is a known problem?
1800.tif1024.tif
Parents Reply Children
