Hi all,
I Like to have an animation with a spotlight on a fixed point, but the spotlight has to follow a path.
Is it possible to attach the direction of a spotlight to a target? And if it is how?
Hi Karol, thanks for responding,
I tried to figure it out , but I can´t manage it. When I attach the Spotlight to the target, the Spotlight is moving with the target but it needs to be fixed.
I have attached the dgn. You see 3 spotlights, the direction of the first one in the row needs to follow the target (which is following a path)
Can you help me out?AnimatieCAM.dgn
Hi Mark,
maybe this Training could help you:
http://learn.bentley.com/app/VideoPlayer/LinkToIndividualCourse?LearningPathID=106792&CourseID=112955&MediaID=5005860
Mara
AnimatieCAM_karol.dgnHi Mark
i send you with new light which is rotating to target ,
you have not to direct to target / as you see my spot with drection down
you forgot script target , spot to target , that is all
look on result , i hope it is what you want
have a nice day
Karol
