in the material editor in the connect edition update 1 is no texture display in the preview of modo thing. Some other display previews (Cube, Cylinder...) shows the texture. It´s only the pattern map. The bump map will be display.
Here some screenshots.
Marc
Hi David,
it´s happening in an own pallet of us. The materials are external not internal like the delivered materials of MicroStation.
I´ve testet it again, and the result is, that the MicroStation materials are displayed correctly in modo thing. Then i saw in our own materials, that some materials are displayed correctly in modo thing and some not.
First, the default preview size of modo thing is not correctly, i thing. Because if you change the preview size from 1 to 100 the pattern is displayed.
The second reason is, if i change the mapping and the units of the pattern from master - planar to surface - parametric the pattern is also displayed.
