is there a clever way to get texture on multiple objects with different orientations - ie wood grain following the long side of my timber pieces...
Try the Visualization Forum — it's full of enthusiastic and expert people who can answer your question.
Hi Chris,
How is your material setup?
You can edit that with Pattern Mapping:
In this case Parametric, cubic, solid pattern does the trick. You should use the mapping that adapts more to your solids.
Regards.
José
