I rendered this interior both in MS V8i and MS Connect (most recent versions).
As you can notice the interior rendered with MS Connect is showing the feared splotches and speckles.
I know how to avoid them in MS V8i.
How do I avoid them in Connect?
Wim
Answer Verified By: wysiwyg
Thanks Jerry,
That did it!
Here two results:
- Direct Light Samples: 0
- Direct Light Samples: 64 (20% render time increase)
Both with Direct Light MIS to None.
I must ad that some mesh mappings are different from V8i (cushing's)
Greatings,
I cannot repro using your settings we must be out of sync somehow. Interior Good -3 with Subsurface Scattering set to both and MIS set to None.
I did edit the white reflective plastic material a bit can you try bumping the efficiency slider down a tad so that you don't have a material that reflects more light than it receives it was around 119% I set this to be 98% this changes the specular to 11 and the amount of SSS to 23.
Jerry
I also adjusted the efficiency of the white plastic.
The result is much better!
It is not the same as yours, I detect one spot.
But again, thanks!
I know where to search now.
