I rendered this interior both in MS V8i and MS Connect (most recent versions).
As you can notice the interior rendered with MS Connect is showing the feared splotches and speckles.
I know how to avoid them in MS V8i.
How do I avoid them in Connect?
Wim
Hello Jerry,
Here the result of MIS: both and samples: 512.
The corners are better, but splotches bigger.
Thanks for your reply.
I'm aware of this setting to avoid splotches.
But another result of turning off "visible to indirect" is: The milky translucency of white plastic is gone! No light is coming threw.
Strange thing: I'm not having splotches in V8i with "Visible the indirect": ON
