Hi,we tested the new update 3 for 2 hours and again we found a lot of bugs.1. Color-Alpha-Layer is not displayed in a multilayer photoshop-file, though it was there in the preview window. For example, Photoshop shows all of our layers (e.g. Color, surface id, alpha, ambient occlusion etc.), but not the color-alpha-layer. See the screen, which i have attached. In the rendersetup i have activated the coloralpha-layer.2. During i want to activate the buttons in render output (rendersetup), we can not activate our wished buttons (see video, which i have attached).3. Connect web browser problem is still there. Defect 340813 (see attached image3.jpg)4. After we have opened our dgn-file, all external(!) materials are not displayed in the shaded view. After i open the material editor with our materials, then i refresh the view and all materials are displayed now. That´s very unfortunately, that we have to open the material editor to see our materials in the shaded view.5. Loading the material editor needs much more time than MicroStation V8i. And if i click on a material especially the "modo thing" preview (luxology) needs a long time for refreshing, too.6. We tested the key-in "define materials", but there are no materials read. We think, it doesn´t works.Regards, MarcHere a video (2.) and two images (1.+3.):
Hi Marc, At this moment I've got a big Visualization project. I think I wait till the project is finished before I update to the next version. Did you also test the projection tools in this update? In Connect update 2, the scale projection is many times to sensitive. In the properties of an object, you can fill in the properties of a projection (!, in the properties tab). Unfortunately this had no effect (today). It happens that textures looks good in shaded view, but that the render looks totally different (rotated, moved). I downloaded a skp file from 3d warehouse. This looked fine in SelectSeries 4. In Connect Edition Update 2 however, all textures where lost. In the material editor I saw that all textures (MsTn was looking for), had a 2 behind the file name. I had to re-link alle textures again.
I also missed the Color / Alpha Layer in Photoshop.
This are some problems I noticed accidentally today. This big visualization project was to heavy to render in SelectSeries 4. In Connect it renders, but unfortunately I had to re-materialize a lot of elements.
Regards Louis
