Benchmark in MicroStation Connect Edition?
1. Is there a benchmark test file in the conect edition? I have seen, there is only a file at 2013 for V8i, but not for connect.
2. What is the best video card for ms connect? I think, if we want to display the geometry with the textures, there should be a very good video card to load the things. We have a titan X and in connect, there are visible faults if i hover over the menu buttons. Has everyone experience with it?
Marc
  • Hi,
    Indeed CE is missing a benchmark, so far only available for SS3. But as always, the faster and available memory for graphic card the better.
    Here you'll find some help:
    Hi Neil, If the CPU Clock Speed is not at maximum it is more then like the BIOS settings you will need to look at, this goes for both Laptops and Desktops. On Laptops further check the "Power" settings…
    http://communities.bentley.com/products/microstation/w/microstation__wiki/4175.microstation-v8i-system-requirements-and-hardware-recommendations-tn
    http://communities.bentley.com/products/microstation/w/microstation__wiki/24799.microstation-connect-edition-system-requirements
    http://communities.bentley.com/products/microstation/w/microstation__wiki/19901.when-i-run-a-graphics-benchmark-test-on-my-pc-s-the-cpu-clock-speeds-is-not-at-maximum-why
    Unknown said:
    2. ...We have a titan X and in connect, there are visible faults if i hover over the menu buttons. Has everyone experience with it?
    Are you using a UHD monitor? Check this:
    communities.bentley.com/.../31077.user-interface-tips-for-high-resolution-monitors
    https://communities.bentley.com/products/administration/f/343321/t/123104
    José
  • Hi José,
    thanks for your answer. Yes, we will wait until the benchmark release of connect is there.
    No, we don´t use UHD monitors. We use three monitors for one pc and if i hover with the mouse over the buttons, the buttons will unvisible and it´s impossible to work with ms connect. I have this problem with the titan x video card. Other video cards, which we have, is there no problem. For example the amd video card for cad. The geometry takes a longer time to build up (display) with a amd cad video card. I test it with a game video card (titan x) and it build up it very fast. That´s my experience.
    I have seen your links, which you have send here. But i want to repair the problem with hover invisble effect. The links are for the scale variation of the buttons, i think.
    Marc
  • Hi Marc,
    Did you check your graphic drivers? First test with the latest ones. If the problem presists use the original ones that came with the graphic card.
    There are some issues regarding graphics and there respective drivers. With some tests (diferent drivers) we manage to get the expected result.
    Hope this helps.
    José
  • Hi José,
    yes, we have test it with an older and the new graphic driver. But no sucess.
    Marc
  • Is this issue only related to CE or happens to other program? Can you get a screenshot? I don't remember see this issue here in communities. I would try a google search based on your graphic model.
    José
