I would like to know what the optimal configuration of computer for Microstation V8i 3D, for 3D use and realistic renderings.
It is not intended to design a complete plant in detail, but simply a few technical premises, followed by a realistic rendering.
We have an envelope dedicated to this purchase between 3000 € and 3500 €.
I received a first estimate, here are the main elements :
- Xeon E5-1650V3
- RAM 40Go
- SSD 256Gb + HDD 1To
- Quadro K2200 - 4Go DDR5
- Windows 7 pro
To your opinion, is that enough?
Sorry for my English ... I'm french boy ;)
Thank you !
MicroStation V8i System Requirements can be found here : communities.bentley.com/.../4175.microstation-v8i-system-requirements-and-hardware-recommendations-tn At the bottom of this article you can find some recommendations.
Planning ahead the MicroStation CONNECT Edition requirements can be found here
http://communities.bentley.com/products/microstation/w/microstation__wiki/24799.microstation-connect-edition-system-requirements
Carl Myhill
Technical Support Engineer
Bentley Systems
I wonder if you need *anything* special for MicroStation these days ... even latest Gen Intel Graphics on CPU can handle 3D to an extend that you get your way.
Unknown said: We have an envelope dedicated to this purchase between 3000 € and 3500 €.
Really? Let's wait for other users advice. But maybe it's better to get a middle-of-the-road average PC for less than 1000 EUR (excluding monitors) and replace it in 2 years by another, improved one. Right now MicroStation does not need high end hardware. Maybe a new feature is needed with some next versions - and then you have budget left to buy another PC to match it. And yet another one.
