MicroStation Connect, import from Web-Browser with "connect webbrowser" doesn´t work properly
Hallo,
we attached to video-files. We tested "connect web-browser" with a cell-library on a network-connected-Drive M:\ and an local Drive C:\ . The HTML-cell-library was generated with uhtml of connect-edition. The other cell-library is our old cell-library, which works properly with V8i.
The import doesn´t work in both cases. The Cell-library is not found. Please check, if it has something to do with the Pathes shown in the dialog. Probably something has changed in Connect, so that the tool doesn´t get the right path.
That thing is so a nice flexibel tool to organize cell-libraries in an easy way. Please Bentley, get this tool running again. It´s so important!
Gerd
Parents Reply Children
